Look at all my crap - Free! cleaning out the garage!
It's not all free but close to it.
Make an offer on anything or just pick it up. I might trek over to Jerrys on Thursday if anyone on that side on town wants anything... Really, most of this stuff is free, just come and get it. I put $ next to the items I felt were worth something (more than me taking the time to sell and make money).
Toyota Parts:
$400 - 1 rear Toyota axle. All-Pro Chrmo shafts in place with bearings and bearing housings, axle housing with too much crap welded on it, 4cy 3rd member with stripped 4:10 gears, Lincoln locked
(4) Toyota OEM rear axle shafts– wide
(1) welded 4cyl carrier
(1) V6 3rd member with caps
$50 (1) V6 3rd member w 4.10 gears, Lincoln locked
$20 (1) V6 4:10 reverse cut (high pinion) gears on Lincoln locked carrier
Toyota 4.56 gears
(2) vented Toyota rotors
(2) 4 piston Toyota calipers
$20 - Toyota pitman arm, All Pro (old school), double sheer
$40 - Toyota steering box, drilled and tapped
Other Crap:
$300 OBO Warn 8K Winch, M8000, cable is not in great shape but still works fine.
$30 Warn 8K winch cable
(2) roller fairleads, one never used - $10
Set of Ford 9” shafts, 28 spline, I think small brg
D60 open carrier
D60 4:10 reverse cut (high pinion) gears - OEM
(2) D60 Ford knuckles
(2) D60 caliper brackets, cleaned and painted, Ford
(2) D60 Bearing hubs – Dodge external lock
Dodge D60 spindle
Box of Dodge mirrors – broken glass 2nd gen tow and stock sets
(2) Dodge chrome dually wheel insets
(2) multimeters - old school
Chevy 5.3 manifolds (2000 vinatge)
Dropped pitman arm – Dodge?
4” lift blocks
Free - (2) Bilstein B46-1072S shocks – need rebuild
