351W Stuff
Stuff from my 351W marine motors. The original motor in the boat had a cracked block and I used nothing from it. The second one was out of a 2001 Nautique and also had a cracked block so I used everything except the short block off of it, but it was the cleanest motor I've ever taken apart. Make me an offer on all this stuff, need it out of the way.
Complete short block (96 hours) from 351W Pro Boss, block is cracked, rotating assembly is near perfect and top of the line components if you had a new block you could swap everything over.
The front timing chain cover (steel)
Chrome valve covers, few small rust spots should clean up nice
Marine mechanical fuel pump
Fuel pump drive
Marine Alternator and bracket, don't know output
marine 4 barrel square bore intake (steel)
Oil pan
valve springs/valves/retainers
pushrods
camshaft or two/lifters (everyone knows a marine cam is better than an RV cam!)
pistons
crank
rods
Pretty much if you want some 351W crap, which should work on 302's as well let me know. The heads and block were crap on the first one, the rest was in "running" condition. I did already sell the carb. Make me an offer on any or all of this stuff, I need it gone and I don't want to dick with ebay on all this stuff. I can get pics of any of the stuff if you need them, free delivery to College Station Tech weekend for sure.
No one wants all the valuable stuff? I also have a flame arrestor for a boat carb. It should work really well on a mud/alto truck! ;)
Still need to move this ****. It will go pretty cheap, need it out of the way.
Have some of this crap still, most of it is in the trailer ready to go to the scrap yard sometime this week. Speak up if you want any of the rotating assembly or anything, free to really cheap. The crank/rods/pistons out of the pro boss block is some good ****.
I am tempted, did JB determine he couldnt use any of it?
