Mongo (toyota 4runner) + car carhauler
http://tamor.us/members-rigs/albums/...0575.sized.jpg
87 toyota 4runner SAS'ed with exo cage
- D60 front (87 dodge) with chevy dually hubs, 6.17 gears, lockright locker, 35 spline stock inners, 35 spline Alloy USA outers, Solid drive flanges, Rockcrusher diff cover, High Angle D60 to Toyota pinion flange, all new brakes, seals, bearings, kingpins etc.
- D70 rear (79 ford), 6.17 gears, 35 spline shafts, lockright locker, disc brakes, Rockcrusher diff cover, High Angle D70 to Toyota pinion flange, all new seals
- stock 22re (gotta check the mileage), W56 tranny, dual toy cases, Sky manufacturing skid plate, 2" drivetrain lift, square driveshafts using toyota yokes and u-joints
- crossover steering (all 1.5"x.25" DOM) with 1 ton TREs, hydro assist, kreb's special steering arm, drilled and tapped toy IFS steering box, fluid cooler, extra large aluminum reservior, All Pro pitman arm reamed to fit 1 ton TRE
- front suspension is a mix of toyota and waggy rear springs, Bilstien shocks, ford shock towers, poly bumpstops, shackle type traction bar
- rear suspension are ford 57" springs from a F150 flipped to face backwards, bilstien shocks, slip and twist type traction bar
- Chevy 1 ton MC with front and rear electric linelocks, stainless brake lines
- 39.5x13.5x17 bias ply IROKs on H2 wheels balanced with airsoft BBs
- interior is pretty much stripped, with fully adjustable seats from a Scion sports car, Corbeau 4 point harnesses, CD player, and brand new CB. The frames for the seats are tied into the exo and frame for extra strength. AC still works but could use a recharge
- Wheel base is ~114 inches, track width is a little over 84 inches in the front, narrower in the rear. Very stable and climbs well. Lots of storage.
$8500 with a 18ft car hauler trailer. Partial trades considered for guns. I'm keeping the puma air compressor. The trailer could use some paint and work on the brakes, but it gets the job done
More pics of 4runner - http://tamor.us/members-rigs/Build-up?page=1
pics of trailer - http://tamor.us/members-rigs/album40
