This is in no way a complete total of the parts, but it should be a pretty good ballpark.
Parts List: $4,433.20
HEADS $2181.84
Patriot Freedom Heads PAR-2211 x1 (set) $1,395.00
Intake pushrods - CCA-7934-1 (Comp Cams) x8 $79.04
Exhaust pushrods - CCA-7979-8 (Comp Cams) x1 $78.95
ARP Head Bolt Kit ARP-135-3603 $92.95
Comp Cams Roller Rockers CCA-1411-16 $145.95
Comp Cams CB 260AH-12 249-K11-302-4 $389.95
INTAKE $470.86
Edelbrock Squarebore/Squareport Intake EDL-7522 x1 $384.88
TBI Adapter Plate TRD-2210 x2 $85.98
CLUTCH $312.85
12" Centerforce 2 Disc CTF-384024 x1 $93.95
12" Centerforce 2 Pressure Plate CTF-CFT361909 $183.95
Throwout Bearing CTF-N1716 x1 $34.95
COMPUTER and ACCESSORIES $370.07
OBD1/USB Tuning Cable aldlobd1u x 1 $59.95
TBI Computer #16197427 (v6 or v8 does not matter) x 2 (one for trail spare) $69.99 (on ebay)
TBI V8 Computer Chip for #16197427 (must be v8) x 2 (one for trail spare) $29.99 (on ebay)
16/18 gauge Delphi female terminal #12146448 x 70 $13.30
20/22 gauge Delphi female terminal #12146447 x 70 $13.30
32 cavity Delphi ECM connector #12110207 x 1 $1.99
32 cavity Delphi Micro-pack 100 connector #12110113 x 1 $1.75
2 cavity pigtail connector #12052641-ASM x 1 $8.99
Delphi terminal removal tool #12031876 x 1 $17.99
Delphi Micro-pack 100 TPA lock #12045889 x 4 $1.96
G1 Memory adapter G1 x 1 $35.00
Replacement memory chip 27SF512 x 2 $10.00
FUEL DELIVERY $627.81
16gal fuel cell w/ foam 2160D x1 $155.99
#8AN Straight End SUM-220890B x4 $27.80
#8AN 45deg End SUM-220886B x4 $55.80
#8AN 90deg End SUM-220886B x3 $44.85
#8AN Hose pre-cut 25' length SUM-230820 x1 $84.95
#6AN Straight End SUM-220690B x1 $4.88
#6AN 45deg End SUM-220686B x3 $41.85
#6AN Hose pre-cut 10' length SUM-230610 x1 $39.95
-6 AN to 14mm x 1.5 O-Ring RUS-648070 x2 $23.90
-6 AN to 3/8 NPT SUM-220648B x2 $5.90
BYPASS REGULATOR AEI-13301 $125.95
BYPASS REGULATOR FITTING KIT 13301K1 $15.99 (Jegs)
EXHAUST $315.95
Headman Shorty Headers HED-68618 $315.95
MISC. $153.82
ENGINE BOLT KIT ARP-535-9701 $91.87
ENGINE GASKET SET FEL-KS2618 $61.95
