Round 2 will involve bigger tires, bigger axles, lower gears, and more lift.
Tires are 35x14.5x16.5 SSR. I know, not the best choice, but they were cheap, and I'm cheap, so we'll go good together.
Wheels will probably be of the hummer variety. Will cut the runflat or maybe make new ones. I don't think there'd be much room between the magnesium runflat and tire and it would make them get cut easy.
Front axle is a Chevy dana 44 HD from Cody's junk pile. 4.10 gears. 69" wide. I replaced all seals, 1 bearing, and both u-joints. I bought a badass $13 sand blaster from Wal-Mart and cleaned it up good and painted it. The carrier was sitting on the table and some welding rods found their way inside. I've got power steering with a slow ratio and I'll turn up the pressure. I may have to go with hydro assist. I ground the lip off the bottom of the housing so it was even with the diff cover, then kept going untill I hit the bottom bolts. Probably only about 3/8" but it is smooth. I built a little diff cover skid plate out of some 3/8" thick, 12" pipe. High steer arms are 1" thick and have a 1/2" spacer under them, I think this will clear the springs. Ordered some QA1 heims from Jegs.
Rear axle is a dana 60 ff with 30 splines. 67" wide. Andy brought it from Louisiana to TCC and thanks to Nick for bringing it back here. Not sure what I'll do for brakes. It will have a Detroit Electrac. OK, I lied, it will be welded. Gears are 4.10. I just got it today.
For springs, I will probably combine my rears with a set of YJ springs I've got laying around. Front axle will be moved 1" forward. Shackles will be 1" longer at 4" eye to eye. No reverse shackles. Plan on eventually doing TJ flares. Front shocks will be the longest cheap shocks I can find. So far, I've found 15" travel procomp but haven't checked skyjacker yet. Rear shocks will be my 11" travel current front shocks mounted at an angle inwards.
Welder and air will also be finished. Also will build rocker guards.
