Quick fix for the locker push...
Originally posted by BMFScout
Now on lissa's TJ with a detroit, there is the same amount of slack but as you apply and let off the gas it gently pushes the heep to the left a little as you apply the gas, and back to the right as you let off. I think this is pretty common with TJ's, but Lissa's jeep is Lissa's jeep, so hard telling. (going to catch hell for that one...)
That problem is easily solved. The reason that the thing pushes is because of slightly different rolling diameters between the two rear tires. Figure out which way it pushes (technical racing term there) and add 1 lb of air to the rear tire on that side until it stops, i.e. left push, add air to the left rear tire.
