I finally found a rear axle for BigRed. Someone suggested Pick-N-Pull in San Antonio so i went down there wednesday w/ Kate. I found a lot of decent stuff, including TWO D60 rears WITH speed sensor. Pricing was VERY fair too....as long as you told the guys it was a 3/4 ton and not a 1 ton you saved $50 for the same sh!t. Anyway...i started to pull the axle wednesday but only made it like 30 mins before the heat started getting to me, so we went back yesterday prepared. We took a cooler full of water, and before starting, put a piece of plywood between the vans on one side, and an F150 hood on the other side so i got to work in the shade. Three hours later, 105* outside, sunburnt still, and about to die of heat stroke, i had the axle at the front (1/2 mile from where we pulled it). Paid $154 for it b.c. i talked them out of charging me a core. I ordered spring perches yesterday. Ordering rims today. still need to talk to brandon about gears.
BRANDON: if you're reading this call me right now 512.468.1604
