yj brakes and cj steering column
Anyone know where i can get the master cylinder, brake booster, firewall mount, and proportioning valve from a yj. Either someone has it laying around which would be great, or does anyone know where a trashed yj is that someone is parting out. And does anyone have a good cj steering column, tilt or non-tilt, manual? Must include working parts, but doesn't necessarily need ignition lock wiring, ignition switch, steering wheel, horn. Basically just want a solid shaft and case and bearings. Both to swap into my 85 cj, the brakes could use an upgrade and my automatic chevy column isn't working to well. The steering is real loose and instead of jerry riggin it more than it already is I would rather just swap out the guts.
I didn't know i was writing a paper, sorry professor.
