Hey guys -
First time back on the forums posting in a long time. I need help in a bad way. I will try to fill you in.
I am finally going to complete the SAS on my truck. It has been in my driveway not moving for about a year and a half now. The big rush now is because I have finally gotten sick of not driving it - I miss it - and also because the city code enforcement office has given me notice and I need to make it a "functional vehicle" - technically by monday. Also - the car that I have been driving kinda blew up on me so my transportation is kinda limited. I have most of the parts I need already - track bar, tie rod, drag link, shocks, springs, axle, pitman arm, etc.
What I need now is help. I need someone who has a welder and some experience and is willing to come to the house with welder. I can def work out some form of compensation. My frame needs welding and reinforcing in two places. I also need to fab a track bar bracket up. I also need two tires at minimum to roll on, don't care what size or anything to be honest as long as they work. I can buy more later. Some extra hands will be needed to get the axle in place im sure. I think that the only pieces I am missing now are the lower coil buckets, hardware, gear lube, and little misc crap. I am thinkin that initially I won't even hook up the driveshaft, run a ring gear or axles in it. I can do all that once it moves under its own power and is off jackstands. Cooper and Eric have both mentioned they could help - anyone else out there? I don't care if I know you or not - I am in a pretty serious bind right now. I am willing to feed and "water" and whatever else is needed anyone who can lend me a hand - I will be in deep debt to you. I am sure I will follow up to this - but I wanted to at least post something up now that I finally can. Thanks in advance.
Seth
EDIT:
I am putting my to-do list here:
Remove TTB - done
Buy Springs - done
Buy steering - done
Buy shocks - done
Buy trac-bar - done
Buy ball joint - done
Repair frame - done
Fab in new front x-member - done
Get new tires - done
Paint axle, arms, cups, etc. - done
Get hardware (x10?) - done
Drill and mount radius arm brackets - done
Buy stock pitman arm - done
Remove drop pitman arm - done
Install stock pitman arm - done
Seperate caps from radius arms - done
Drill/tap spring cup mounting bolt holes - done
Attach radius arms to axle - done
Get upper tracbar mount bracket - done (thanks frick)
Pull old brake lines - done
Get new brake lines - done
Install brake lines - done
Charge battery - done
Clean up spindles, pack bearings - done
Get new spindle nuts - done
Install brake calipers and pads - done
Bleed brakes - done
Install shocks - done
Replace spindle stud
Repair exhaust
Install new ball joint
Alignment
Make shims for under spring cups
Install shims
Have front gears installed
Install front driveshaft
Install hubs (buy new ones?)
Install axle shafts (with gears?)
Have rear gears installed
Shackle Flip rear axle
State Inspection
Remove Body Lift (redo front crossmember)
