Originally posted by eight
One of the starer solenoids like ford uses on the passenger side fender of a diesel should work. I'm not sure if the gas trucks use the same thing.
Did you do anything to the computer to adjust for the new cam? You usually need a custom chip, fuel pressure regulator, or bigger injectors.
A diesel glow plug solenoid is what overheated most recently. I dont want to just use a relay b.c. for some reason, if i use a relay i'll burn up switches. I did it once this summer and was told that i need to use a solenoid to keep it from happening.
