Wow, I never realized you were so ignorant. Do you not understand that the ****ing pinion and caster problem will be fixed by shims. The caster angle is pitched upward and pinion down, when I shim it, it will be level. You really don't listen when you make comments like that, I already have misalignment washers that I will put in there and if that doesn't work then I will go to a spacer.Quote:
Originally Posted by uglyota
This isn't rocket science, so why try to overengineer everything, just accept what's been said. :gigem:
