yes i think the order of asymbly is different, cause the backside locating ring on a ford spindle is taller so it will reach the knuckle bore
radiators? jeep needs a new radiator, should I put a one row aluminum or 2 row alumimum. will I notice the difference with the two row?
stock is a one row with plastic tanks
i'll sell ya a dual pass 2 core aluminum one for $100. that ought to keep it cool.
Does it bolt in to a tj
why not put a stock replacement back in?
isthat the original? I think 10 year radiator lifespan is acceptable. I bet its cheap
a new tank is less than 40 iirc with a cleaning
no its actually the jeeps 2nd radiator. They can crimp on new plastic tanks and them not leak?
sweet too bad I am not in bryan. I just went ahead and ordered a 2 row all aluminum all welded radiator for 145 shipped. Not too bad a deal and it bolts right in to the jeep. Hopefully I won't have any more problems and If I do I can weld them up.
Can I use the front output yoke from a 205 on the rear side of the my 205?
