I have a spare set so I'm thinking about sending them to witchhunter for $18 each, but I'd like to try the easier and (hopefully) cheaper flush first.
if you have a spare set then it just turns out that you are too lazy to swap them out
stuff with big upper plenums aren't the easiest engines to swap injectors
I see. I guess you should send your spare injectors out to be cleaned and then swap them so you only have to **** with everything once
If I were you I would just convert that ho to dual TBI and be done with it :flipoff2:
it would probably start quicker
I say you get rid of it and use your student loan money to make payments on a new truck.
Anyone know what the fitting size on a Wix 33481 is? I.E. I am trying to find AN adapters and Jegs has 3 different sizes, but I dont not know which it is and do not have the tools to measure one here.
Look it up on the Wix website, it lists fitting sizes there.
Is there anywhere in town I can get a tiny (~3/8 x 3/8 x 1/16") piece of high density plastic? Exact material isnt important, something like Delrin or teflon will probably work.
