I think bungee cording an actual refrigerator to the bed is more Klogger style.
Doors still fit
http://i736.photobucket.com/albums/x...V/IMAG0219.jpg
http://i736.photobucket.com/albums/x...IMAG0218-1.jpg
Rear cage mounts. The bolt goes straight into the body mount. Tried to make the foot big enough to spread out the weight.
B pillar frame outrigger. gonna add some gussets
http://i736.photobucket.com/albums/x...IMAG0215-2.jpg
Dash started
http://i736.photobucket.com/albums/x...IMAG0214-2.jpg
are u putting on a turbo? why the boost?
Supercharger actually. Tommy got one real cheap on craigslist. We're going to do a draw-through setup. I have the book "Turbochargers" by Hugh MacInnes that has a good section on draw-through setups for carbs.
No pro-charger?! It's the best of both worlds!
Yeah, shouldn't see more than 6 psi with the setup we are gonna run. Guess the secret is out now......
Go ahead and see if you can have it clutch engaged while you're at it.
"You can shut the gate on this one, Maxie. It's the Duck's guts!"
"She sacks Nitro. Phase 4 heads, 600hp through the wheels, she's meaness set to music and this bitch is born to run!"
So are we staying with the 2 barrel ?
We might try to find a 4100 which is the same thing but 4 barrel. Tommy's **** doesn't run anyways
Doesn't someone make a fuel injected carburetor that might work?
