bdr randys r&P had dana 44 thick gear sets for like 150 new that doesnt seem to bad to me.
my blazer is a 90 and it has vss, after i swapped the transfer case out i havent figured out a way to plug it back in, because of this my transmission doesnt shift right(it holds first and second gear to long and i dont think i have ever made it to third), other than that every thing seems to work find
Ya, the USA Standard brand. I haven't found much information anywhere about them. The information I have found sounds like they are hit or miss. I'd like to go with the Yukons since they've been pretty reliable all around, but a set of those from Randy's is $219.
Ok, change of direction.:D
Karl delivered a sweet piece of Klogger history yesterday...the Ford 9". Plans are to narrow it to 57" wms, swap to 4.56 gears, weld it, and some sort of disk brakes. I'll need an e-brake, so I'm thinking since I already have the d44 disk parts I might see about making an adapter bracket. If they won't work I may look more into the Ford 8.8 disk brake swap. I can do that when I narrow it because the 8.8 brackets supposedly require the Torino ends.
Built the shackle hangers this weekend. Picked up the sleeves and bushings from Coop and Scott on saturday. I kinda messed up cause I made the hangers centered, and after I had already drilled the holes for the sleeve remembered they need to be offset. I'll just trim the end off that hangs past the bumper. Also had to make a couple extra trips to Lowes. I drove out there when I realized that the YJ bushings take 9/16" bolts. Came back and got to working, then realized I need a 9/16" drill bit to make 9/16" holes for 9/16" bolts through the shackles...so I went back.:rolleyes::laughing:
I'm not sure about the shackle angle. I figured since I'm using the stock springs, I should mount the hangers the same distance apart. At that distance the shackle seemed like it leaned too far forward, so I moved the hanger 1" closer. What do yall think?
http://i267.photobucket.com/albums/i...7/DSCN2409.jpg
http://i267.photobucket.com/albums/i...7/DSCN2412.jpg
I also finished the caps on the backside of the bumper.
http://i267.photobucket.com/albums/i...7/DSCN2410.jpg
Spring hangers done. I'll make some nicer shackles once I get it back on its wheels and figure out how long they need to be.
http://i267.photobucket.com/albums/i...7/DSCN2265.jpg
http://i267.photobucket.com/albums/i...7/DSCN2267.jpg
http://i267.photobucket.com/albums/i...7/DSCN2269.jpg
http://i267.photobucket.com/albums/i...7/DSCN2432.jpg
http://i267.photobucket.com/albums/i...7/DSCN2433.jpg
Almost done shaving the front axle. I used the "bucket method" pointed out in the ford 9" thread to mark the housing.:p
http://i267.photobucket.com/albums/i...7/DSCN2434.jpg
http://i267.photobucket.com/albums/i...7/DSCN2435.jpg
http://i267.photobucket.com/albums/i...7/DSCN2436.jpg
http://i267.photobucket.com/albums/i...7/DSCN2438.jpg
With some cleaning up and the old drain plug hole filled.
http://i267.photobucket.com/albums/i...7/DSCN2439.jpg
3/8" plate for the new skid. I don't think I'm gaining a whole lot of clearance, but the skid will be nice for sliding over rocks. Looking back, I don't think I should have extended the cut into the front cover, but should have stopped where the cover meets the housing. It's going to be a bit difficult to get a nice transition from the cover to the plate without a lip. Should be ok though.
http://i267.photobucket.com/albums/i...7/DSCN2443.jpg
super nice work! Should be easy to drag onto the trailer next time you have to move all your crap :flipoff2:
Finally an update! :D
Skid welded in
http://i267.photobucket.com/albums/i...7/DSCN2451.jpg
http://i267.photobucket.com/albums/i...7/DSCN2475.jpg
I picked up some ring gear armor. It was made for the 8" pickup axle but with a little massaging fit just right. Butting it up to the skid also smooths out the transition.
Guard tacked up
http://i267.photobucket.com/albums/i...7/DSCN2463.jpg
I had to make some small filler plates at the corners of the skid
http://i267.photobucket.com/albums/i...7/DSCN2466.jpg
Everything welded up and smoothed out
http://i267.photobucket.com/albums/i...7/DSCN2478.jpg
Picked up a Marlin knuckle gusset kit. The upper one seems a bit overkill but it also serves as the shock mount.
Lower tacked up
http://i267.photobucket.com/albums/i...7/DSCN2468.jpg
Upper tacked up
http://i267.photobucket.com/albums/i...7/DSCN2469.jpg
All welded up. I left the end of the upper near the knuckle bearing unwelded because it will probably need to be ground some to clear the knuckle felts/wipers.
http://i267.photobucket.com/albums/i...7/DSCN2472.jpg
I decided to relocate the fill plug a little higher. With the pinion rotated up I lose a bit of oil capacity. I started to put it near the top of the cover where it would face up but decided not to. For one the high steer would be in the way when I go to fill it, also I would need to make some sort of dipstick to check the oil level. I used a Ballistic weld in bung.
I cut the old plug out with a hole saw then filled it
http://i267.photobucket.com/albums/i...7/DSCN2470.jpg
New bung installed
http://i267.photobucket.com/albums/i...7/DSCN2471.jpg
You can see the difference from the inside
http://i267.photobucket.com/albums/i...7/DSCN2476.jpg
Looks good! I need some shackles also. :)
Couple more pics of everything cleaned up
http://i267.photobucket.com/albums/i...7/DSCN2473.jpg
http://i267.photobucket.com/albums/i...7/DSCN2479.jpg
This should be it for the fab work on the front axle. Only thing left to do will be to fab up a truss/brackets to mount the hydro assist. I probably won't do that till later in the build.
I've got about 99% of the parts I need to put this axle back together. I need to source some hardware for the steering arms. I need to start cleaning things up for assembly...somehow I've got to figure out how to make an axle out of all this crap...:laughing:
http://i267.photobucket.com/albums/i...7/DSCN2467.jpg
I've also been working on the Ford 9" swap. I was going to use the housing I originally picked up, but after cleaning it up a bit found a lot of pitting. I feel if I'm putting so much time into this thing I should get a housing that doesn't look all pitted after it's cleaned up and painted. I've been through a couple other housings since then that just didn't work out...seems I've got a bit of a Ford 9 graveyard going. :laughing:
http://i267.photobucket.com/albums/i...7/DSCN2449.jpg
http://i267.photobucket.com/albums/i...7/DSCN2480.jpg
looks like you need to put the potting soil down and get to work :flipoff2:
:laughing:
Picked up the last of the hardware for the steering arms yesterday. Still gotta pick up some moly grease, a few wheel studs, and some ospho. Got the day off Friday...should have a complete axle by Sunday!:beer:
