my limited knowledge of rear mains is that you can put a one piece in place of a two piece. i think. so they should have put a one piece in, and if they didnt, you prob could?
Sorry, dont know much about Fords, I do know all I need to know about boats though :flipoff2:
is that the eye of katrina?
I think all windsor blocks are the same except deck hieght for 302 or 351
Did yous pistons look like that?
http://tamor.org/forums/showthread.php?t=8954Quote:
Originally Posted by agjohn02
I've got less in mine... :flipoff2:
On chevies, no. The one piece mains have a little plate that bolts on the back of the block to hold the seal in while on two piecers the seal is retained by the block and rear cap.Quote:
Originally Posted by Seth
I dont think in 77 they were doing the one piece rear main.Quote:
Originally Posted by BMFScout
Also I would take that high volume oil pump and throw it in the trash they are pos.
****ty Motor Supply installs a high volume Melling oil pump and supplies a full engine gasket set with every rebuilt motor.
...I hate having collins bros flashbacks.
So the seal design sucks, will the rest of it work cause that's real cheap. That block with all my pro-boss **** on top? Mainly worried about the flywheel maybe?Quote:
call a marine shop service dept and ask them. tell them you need it installed, and wanted to know if it will work before you buy it and bring it to them... ;)
Thats super for city motor supply I had a high volume melling oil pump turn one of my 302's into a giant paper weight. After 30,000 clicks.Quote:
Originally Posted by bburris
Jimmy I dont see why the flywheel would not fit. Just make sure you have the right imbalance. Ford used a 50oz and 28oz. I know ford switched around on the 302's but on the 351w I think they stayed with a 28oz.Quote:
Also I think you can put a one piece seal in that engine. If this engine was rebuilt I bet someone already changed that out..
I would also suggest you get the 1 piece oil pan gasket. They cost a little more but they dont leak.
If it made "30,000 clicks" that's probably a machining defect. I mean, clicking out of an engine is never good. :flipoff2:Quote:
Probably a machining defect between the seat and the steering wheel. :flipoff2: :laughing:Quote:
Originally Posted by Fredo
A marine shop told me that boat motors are completely different from car motors. I think they may be full of **** except for the head gaskets. It all looked the same to me.
someone told me that marine engines have been blueprinted and balanced, while cars are not, but i dont know if its true or not. the guy probably just wanted to sound smart
