I parted out a 4th gen Camaro a while back and kept the steering column to use in the Jeep. Two reasons, it is black instead of tan like the Jeep one I had and the multifunction switch on the blinker is in good shape, unlike the Jeep one. They are both GM columns, so almost everything is identicle. The Camaro column has the same double D shaft that fits the Jeep column underhood, but it is slightly longer and had a firewall mount welded to it. The upper mount on the Camaro column was different too. I was planning on modifying the Jeep pedal bracket to accept the Camaro column but I was easily persuaded to do it the other way around when I broke one of the aluminum collapsing pucks. I only had one bolt in and grabbed the wheel to get in. Anyhow, I cut the Camaro brackets off and replaced them with Jeep brackets. I cut the little threaded bosses off of the Jeep column and welded them to the Camaro column. It all bolted up after that.
I cut the support rod on the right side of the column mount that goes to the firewall off when I was planning on adapting the Camaro mounts. What does it do? Should I put it back?
One problem, the column is pointed to the right just a bit. I'm using all the same Jeep mounts and the firewall mount is scooted all the way to the right. Make sense? Any ideas?
