I'm running them and have had zero issues.
Is the 6.4L PSD a giant turd? Maybe just the 08s? DId they have it all worked out for the 2010 models? Friend of a friend uhh, wants to know.
yep still a giant turd that gets horrible fuel mileage, apparently the 2011s are supposed to be alot better
2011's are also a completely diff motor, you know right? Talked to a guy today who has one, 17.5 mpg.
too bad you bought them already - get the Longfield ones. Simple is bettter.
The 6.4 was a navistar motor like the 6.0, a giant piece of ****. The new motor is a ford motor and is supposed to be awesome.
yeah, that 7.3 was a real turd, not to mention all those 444's out on the road.
I thought the 7.3 was a ford motor?
So for my doubler I'm going to go with poly fabricator bushings to mount the crossmember. I have heard that if doing that you should swap to poly motor and trans bushings.
Are the standard and auto trans crossmember bushings the same or will I need a standard trans crossmember bushing?
This energy suspension kit should all I need.
http://www.summitracing.com/parts/ENS-3-1130G/
