Are you willing to get rid of said throttle body?
If not I might try the cleaning route, just never had to do it before.
They can be mounted on top of the axle as well. I didn't have the room on my truck to do it that way, that's why they were mounted below the axle. Rusty uses these same bars on his blazer (the beater) and has them mounted inboard above the axle.
So Oct. 11th I will be in town for a foosball game. Can I grab it then?
ya, i wont be here but ill clean it up and tell sharpe to give it to you
Karl are you really replacing your throttle body with a clean one instead of cleaning yours? Srsly? Get a can of brakleen and roll of paper towels and get after it :flipoff2:
I have already tried to clean it like that. It requires more than that, it is pretty well fubared. I have tried carb cleaner, then lube it with various penetrating oils. It just sucks
You need it sooner? I could grab it tonight and bring it tomorrow.
Picked the throttle body up on Sunday, thanks Clarke.
* Throttle Body done
* Throttle Cable fixed
* Driver's seat done - The seat frame was cracked, had to weld it up
* Fan Shroud looks good
* Ran to issues on the power steering, fixed it here http://www.tamor.org/forums/showthre...856#post212856
* Wiring harness for Cheby should be in Saturday
* Working on brakes tonight, Carrie can help me bleed them tomorrow
* Got the radio in, put it in this weekend
* Check trailer bearings this weekend
* Load cooler on Thursday!
I am getting excited. I gotta check you new PS out.
