I'd think so.
Heck, AL double beadlocks for $800, unmolested factory stuff - I'd be willing to bet they would hold up - would have to be built to mil-spec.
they are bad arse rims we put a set on our h1 they took a pretty good beating after the factory ones had already givin' up. I thought the military still used 16.5's and that is what we had on them. we also had to grind the **** out of the center bore to fit, but I checked one of my ford front hubs and it lined up perfect.
The HMMWV's do still run 16.5's on all of them I have seen here. They do have a new tread pattern I would like to check out though. I didn't read the guys reviews, but if what he says is true, then they should be a good rim. Do EET!!!
What shocks are you planning on running?
i already have them, the same as i have in the rear, bilstein somethings
cool beans, you will love the difference they end up making
i just picked up a set of used rims and a new set of stauns for 550 total, ill get pictures when they get here
bad ass!!!
now its time to egg brian into buying the super charger from me so he can destroy his transmission faster
Hmmmm, tell me more...
i would try and get this on for the trip, but i dont think i will have enough time to get that done, the new rims and stauns on, build a cage and other misc stuff
i got my twin stick done and i am almost sure i got the trans leak fixed, now i just need to do the stauns for this weekend
So no more crawling under the truck to switch out of 4lo, that is awesome!@@@!!!!!
Try and take some good pictures of the staun install, that would be interesting to see.
ill get some pictures of the twin sticks tomorrow when i am working on the stauns, and just for you ed ill take some pictures of the staun install
i didnt get any pictures of the staun install(ill get some when i install the rear ones), here are some pictures of the twin stick, they work great, now i just need a cutting brake so that i can do a decent front dig
