i also got the front shocks installed, and here are a few pictures of my broken drive shaft from this last weekend, i called jesse and he said that he would fix it no charge, but i did make a square one just in case i dont get it back in time
and here are some pictures from last weekend
ive got some 2 inch sch 80 in the back of the truck (well if I ever get it back)
i sent it off to jess at high angle and he is going to hook me up with something, ill give him a call thursday to see what he thinks and also see about getting something thicker put on it
been working on the blazer, i have done some work on my cage, its not done but i do feel much safer now, i got it tied to the frame and also the a pillars and windshield cross bars installed, now all i need is some more triangulation.
i also built version 3 of my trans crossmember, if this one fails it will be a sight to see, the main cross tube is 2.5 square .25 wall and the rest is 3/16 to mount to the tcase
edit: now all i need is some paint and to install it to be ready to load up for trees this weekend
sweet, I hope that I won't have to weld that one back together. do you have any pictures of versions 1 and 2
turns out this is version 4, i forgot about the first one that i had to ditch cause the driveshaft hit it, that can be seen on page 6 post 81, version 2 i cant find a picture of and version 3 can be seen on page 13 post 182
ive only got 11 pages total
http://www.tamor.org/forums/showpost...9&postcount=81
http://www.tamor.org/forums/showpost...&postcount=182
Man yall are lazy (you've been hanging around me too long. :D )
Nice. That one looks like it should do the trick!
What thickness are the bushing sleeves?
1.75 dom .120 wall
