looks better than mine
things to do before tcc
build anti wrap bar-hopefully this weekend
install new hydro assist ram-This weekend
install new seats
replace seals in t-case
adjust and grind hood from narrowing,along with doing something about the grill
install new safety harnesses
pic of seats
that flat expanded metal, not the tread plate kind, with a ferd emblem on it might not look too bad in there if the plastic stuff gets to be a pain
yeah the plactic crap in in the trash, the main part of the grille i was talking about was the outer shell that is in three pieces that we got into the tig discusion about.Quote:
Originally Posted by agjohn02
im thinking do like you said or else take some half inch or so pipe and make one out of that. We shall see.
i think someone mentioned this, but im sure that is some sort of pot metal and maybe chrome plated? it probably wont weld for crap. ive watched even very good welders tig pot metal after it had been thoroughly parts washed, boiled, and cleaned and it still just barely did ok. it wasnt near that thin either. id look at all other options before i tried that. two part epoxy and a backing plate of aluminum sheet might do well.
Are you going to do anything with your grill insert? If not I would probaly be able to take it off your hands.
yes i concur and have decided to go another way beside welding, prolyl just use the cut out pieces and epoxy, screw it all back together
new psc ram installed, i need to get some more air out of the system, and replace my rag joint though
messed with the grille some today and got it all back together. I also cut the front bumper to match, and grinded down the welds on the hood. Then got the hydro assist all bleed and put back together. i can feel some difference from the 1.5 ram to the 2 inch. the 2 inch isnt as responsive, but i expected that.
looks awesome frick
what did those seats come out of? They look familar. Also, how about a side shot, or one from above to see just how much it pulls in
the seats are out ofa dodge neon 2004 or later model, ill try to get a pick from above later today.
did you get them out of a local yard? I seem to remember nearly grabbing a set of similar seats
no they came from south texas, but im pretty sure dodge made some more seats just like that pair :gigem:
Looking snazzy frick. Nice work!
