I was just thinking aluminum for the sake of rust.
St. John can still tig it up:flipoff2:
does Al tube bend easily... as in not crimp or rupture? i dunno. id do it out of steel and powdercoat just to keep from having to experiment with bending Al.
Quiet! We need a guinea pig.
10 second search...
good point! jimmy, you havent a hair on your nuts if you dont build your own tower out of aluminum.
Looks badass Jimmy, if you're worried about the neon looking canadian just fly the Stars and Bars! Problem solved!
http://www.hardwoods-inc.com/Products/concrete.cfm
is this what you used? or something similar...everybody has there own name..I think there is a bunch that comes out of Brazil. This stuff is from China.
there are two different types..paper faced and the resin faced...resin one being better.
$40 a sheet is good. I think most places it is around $80.
Plenty of towers are built of carbon steel and painted. Towers are very expensive for all they are. I wonder what 304SS tube costs...
Most of the towers for boats that look good have long radius bends. It's hard to make a tower look good with a normal bender.
if you did it yourself though, you could peemp it out though.
http://bierbower.net/diytower/home.htm some good links on making one yourself.
http://www.wakeworld.com/MB/Discus/m...tml?1118980059
this one isn't too bad, no long radius bends on it.
That first one sure is slick though.
http://www.wakeworld.com/MB/Discus/m...921/375150.jpg
You need to get copperhead fab (or anybody w/ a plasma/waterjet table) to cut some ATM and Tamor salute gussets out for ya. :D
