Those black boxes look pretty sweet, but pricey. It'll be awhile before I decide on or can afford a doubler, atlas, etc... I'll just find a 205 for cheap and run it for now.
Here's my wishful list of things to accomplish over the winter break between hunting.
-Finish welding on stretch kit
-Make new upper rear shock mounts on frame
-Cut/turn/redrill 1-2" foward on new rear perches
-Lengthen rear brakelines
-Cut sections of the cage out for fuel cell and new dash setup
-Run new fuel lines and install fuel cell
-Pull old drivetrain
-Make new motormounts/tranny/t-case crossmember with new plasma
-Go through 350/th350/205
-Cut floorboard/drop in new drivetrain
-Lengthen/Shorten front and rear driveshafts
-Build anti wrap bar
-Install chevy power master cylinder
-Decide on radiator/electric fan setup
-Connect throttle cable/engine electrical/shifters
If I can scrape up the skrilla buy chromoly rear shafts from Clarke and figure out something for the front shafts.
There's several other things I'll need to get done over time as well such as redoing parts of the cage, building stinger/radiator hoop, front tube fenders, gauges, c.b., and sound system.
My objective is to get as much as I can accomplished over the break and have it ready before TCC.
