You couldn't smile for the picture??
sam after alto consumes his life
http://t3.gstatic.com/images?q=tbn:A...TVBr6u9MjI3vus
Cell service might be sketchy. Take the main road to the back of the campground, turn left before the road heads down to the mud pits and just look around.
713-398-5405 Call/Txt if lost.
HEB run then pick up the trailer and on my way
Hitting the road in about an hour. See you guys there at 6:30 or so.
i may not leave till late friday.... to much going on at work.... see you sat morning
I will be leaving tomorrow morning after class. I don't get paid till midnight anyway so I can buy fuel and beer. .I'm driving the bronco because Sparling had something come up.
Keep the beer cold and the women hot for me.
2:39 am just finished making jeep wheelable.... new brake mc, clutch mc and slave, coolant in the radiator (water alone sucks ;) ***), fix brake lights, etc etc. gotta do some work. then go to work then make brian drive my tired ass as i rest up for a night of debachery.....
I have towed my parent's 1999 tahoe 4 door for 4 hours at highway speeds (65mph). Interweb research shows the tahoe weighs around 5500 lbs and the internet does not lie. A bone stock 1982 F-150 with V8 and 4WD tips the scales at around 4200 lbs. Now I removed the bed, but added a crew cab, so call that a draw. I added 1 tons, compared to a TTB 9" thats a few hundred pounds plus 42" tires. I think I am sitting at 5000 lbs on the klogger, keyword think. As long as there is no crosswind the wind resistance should not be an issue as the klogger tucks behind the camper.
The bago is equipped with brake controller, a 460, a C6, and a dual rear end capable of holding down 10,000 lbs, so as long as the rest of it does not fall apart and I keep feeding it gasolline, it should go.
Who is leaving from Aggieland after 4PM?
There is a chance I will make it if the Bronco doesn't overheat! I miss me some Shiloh Ridge :)
Holy ****
