and yes i know the exhaust looks weird but it isnt as close as it looks and if you look at marios truck its almost the same
Nice military fuse box.
that looks great. did u just use regular blockhugger headers? I used em and then got my exhaust done, but they started to tap the frame and blow the top of my gaskets out. i had to clearance the frame a bit to keep the flanges from hitting...then i had to cut the cross pipe out again and redo.
Originally Posted by Violentv8toy
yeah i got the huggy headers on it. but i set the motor real low to keep a low center of gravity and also to clear exhaust flanges and dist. i didnt even have to modify the firewalll for the cap.
so when do i get a ride :flipoff2:Quote:
Originally Posted by J Cooper
That's noting to be proud of :flipoff2: :laughing: So now you have a pickup with no room in the bed to pick anything up?Quote:
sure i do there is like 2 feet behind that tire... and the tire is just sitting there not like i cant just pull it out. still better than the back seat of a jeep.
hey the fishing was good and i was in a hurry and i didnt see you looking for meQuote:
btw, charlie sounded damn nice just idling there, i think it might need a cut out in there just for those days when u fill like pissing off the nieghbors
so last night me and eric decided to fix my gearing issue...
summary:
red neck that sold eric truck said it had 4.88s
busa told me he sold the guy the rear axle from gregs toy
found out gears were mismatched- lower in front
assumption: stock rear 4.10s front 4.88s
eric finds me a 3rd member with 4.10s for front
pull apart front find it ****ed up and its like a ~3.8 ratio WTF?
eric decides the gear oil smells like a big black lunch ladies bonch
check rear ratio ~3.55s WTF??
so now we have 3 3rd members- all with different gear ratios
now have 4.10s in front and need yet another 3rd member for the rear now
then i went to the hall
... jason was drunk
and i also broke my thottle cable so now i drive like this
http://tamor.us/members-rigs/albums/ideas/untitled.jpg
are you having any cooling issues with that thing? esp with the exhaust wrapping around the oil pan?
no, not at all, thats a pretty common set up
this thread is worthless w/out drunk pics of hensel :) The part of the story I don't believe is that something axle related from Busa was trashed ;) What is a bonch?
na, the axle from busa is fine, it just has a wierd ratio.. the red neck front is what is messed up... and ive already fixed lots of stuff on it already
i dont know if i should describe a bonch in this thread, its public
we think the rear is fine. easy to say, sight unseen :DQuote:
don't forget that the birfs were fine, we replaced axle seals and the rusted out top trunion bearings that nobody in America seems to know about, and once again Eric had to come over to save the day before 218 became a superfund site :D
and you would have to mix tater tots with the gear oil to get the exact smell...it was close to the same smell though...purely speculation though :laughing:
