Originally Posted by
RCcola55
Huh? So you are saying bridging the channels, thus reducing resistance will cut your power output? Go re read your physics book.
Travis find out what the amp is stable at then wire you voice coils and amp to match. Wiring them in parallel will be have the ohms of one coil, in series will add the ohms together. Then run to the amp. Same thing goes for the amp outputs, bridged will reduce ohms at the amp. Too little resistance gives you a lot of bang but can over heat your amp.
