brian, I went a got it out of storage, its a 14" not 16", still interested?
i think thats a little small for for the blazer, even though it was going to be a spare
I'l bring it and you can take a look.
ok
(2) 15X10 Steel American Racing AR767 wheels, black, 5x5.5-$35
(3) 255x70x16 Goodyear Wranglers. 25% tread left, some cracks, hold air and were driven on until today. Make good rollers or cheap work tires/spares-$5 each
YJ Power Brake Master Cylinder with fittings to attach CJ brake lines, bolt it up to a cj or yj. -$15
Dana 30 3.73 ring and pinion (Used) -$35
14" electric fan, brand unknown, works fine-$10
cj7 drivers side side view mirror, faded-$5
Chevy Left and Right d-44 knuckles (non-flat top) with balljoints and spindle studs-$40
d-44 driveslugs-$40
ARB bulkhead fittings kit-$10
Reamer for cj7 tapered tie rod/drag link ends 7/16"-1" (only used once)-$25
Stock CJ7 Pitman arm-$10
F-250 pitman arm, looks like a 1" drop, stock-$10
Stock d-30 cover-$10
Assorted Emblems, Speak Up if you see one you want
Interested in the drive slugs. Do they fit all 44s? Specifically, 78-79 hp44?
mmmmm. Don't know. Maybe someone else could help out. Came off of chevy outers from Brian's Blazer's stock front I now have in the Jeep. 19 spline shafts if I remember right. Can get you measurements and spline counts if needed.
they are from a waggy, the housing is from brian, 8 lug from something i parted out and dslugs are waggy. they should work in any d44 that is 19 spline and internal style hubs
