Originally Posted by J Cooper
300's are oil slingers. all the same stuff spins while in neutral, the dogs just arent engaged.
It sounds like your Grandpa, much like mine, didn't really fall under "most people"Quote:
sell it, buy a pos jeep and taint it up
Nope, note quite right. When the input shaft spins, it will lubricate. But with only the rear output spinning it won't lubricate fully. You can weld tabs to one of the output gears to get it to sling enough oil but without that, you will eventually fry the 300. Towing is limited to 300 miles. Beyond that you have to start the CJ and run the tranny in gear with the t-case in neutural for a few minutes every 300 miles. Or disconnect the rear driveshaft.Quote:
Originally Posted by agjohn02
actually its 200 miles. i looked it up in my jeep book after i posted that. i dont completely understand why the input has to spin to lubricate. i had mine apart last year and didnt see anything that would indicate that, but then i wasnt too worried about it since i dont flat tow.Quote:
Originally Posted by mark
well I just had mine apart, I think it is because the input gear drives the idler shaft and w/ it in neutral it doesnt spin the idler shaft therefore not fully lubing everything.
doesnt the idler spin when in neutral?
so just leave the engine idling, trans in gear, x-fer in neutral whilst you tow
edit: i just remembered how they work, the dogs are between the input/output and the idler. when towing in neutral you're just spinning the rear output shaft.
Yea mine says to run it every 200 miles, but it also says to leave it in gear and put the sr4 in neutral.
from what i read the d20 should be in gear and trans in neutral. the d300 should be in neutral with the trans in gear.
