Little lower than I would consider right now. Thanks tho.
more info on it...
http://www.warn.com/truck/winches/95xp_winch.shtml
FAST, POWERFUL AND RELIABLE - FOR EXTREME CONDITIONS
The fast, powerful WARN 9.5xp Extreme Performance is designed for the serious off-roader who demands a winch that will perform under the most extreme conditions in the world. With 9,500 lbs. of pulling power and the fastest line speed of any WARN winch under load, the 9.5xp delivers extreme performance that eats up the competition-even in competition. The 9.5xp winch features the High Output Parallel Series Wound winch motor that's the strongest and most durable in the industry. The 6 hp motor, 3-stage planetary gearing and extended-duty control pack work in sync to tackle the most demanding pulls. Full face contact drum seals, motor and end housing gaskets deliver extreme-duty water resistance. A high gloss, chip resistant powder coat finish over primer coated alloys affords superior corrosion resistance.
Direct from Warn it is $1500 but through 4wheelparts it is $1030
http://www.4wheelparts.com/Winches-W...&t_pn=WAR69502
Sold!
Whoa, now that was a trip on the way-back machine! :eek:
I was about to offer $700 :(
was probably to low anyways
yeah the guy bought it for 800, but if he hadn't I would of gladly sold it to you for $700. Give a college guy a good deal.
