here is a krusty schematic to illustrate how mine are ran. I run dodge intrepid fans which i think are superior to cli-taurus fans because they are a dual fan set-up with a shroud that fits scout radiators perfectly and are thin, plus the twin set-up allows to set a fan motor on either side of the water pump pulley. I am controlling the ground side of the relay like the factory does and right now the temperature switch I am running is a factory 210 or whatever that is hotter than i would like it to be. If I ever get the scout running again, I will buy a low temp one from jeg's or some place. I use the big round GM relays for everything electrical because they are easy to "obtain" with the connectors from any jy, and are at EVERY parts store, and I can carry one spare for everything, lights, fuel pump, fans, etc...
