If you are thinking about buying a High Angle Driveline then do a search and read about complaints that myself and Troy have had with High Angle shafts. It's all marketing based off the Pirate bulletin board. I don't know of anyone off of Pirate that gives two ****s about High Angle. You can get a shaft made for a lot cheaper by someone local and it'll suit your needs a whole lot better. It can be done on the cheap if you want it to be...
