bronco is not going to make it
couldnt figure it out ehQuote:
Originally Posted by RCcola55
hey how many miles do you have?
http://www.autosafety.org/article.php?did=362&scid=
AH HORSE****! Grow some sack and knock that ***** out!Quote:
I thought this was going to be a newbie run? Do we not have any newbs to bring along?
So far it's looking like Ed, Scotti, Creighton, and myself......anyone else?
I'd go if it were a different weekend. I must have missed this one before... I've already got some commitments.
212000, im lost on ideas about this pos
http://www.racepumps.com/
And I am out because of Davido's pre-wedding shindig...sorry
me and flem replaced the pump and jumped the relay, the fuel pressure was still too low so we then unplugged the reg., she ran fine for like 5 min then acted like it was going to die whenever i touched the gasQuote:
Originally Posted by agjohn02
bad regulator?
normal when the regulator goes bad on these motors the fuel pressure goes way up, they are the diaphram/vacuum controlled type, and the damn thing is brand new
does he volunteer to work on everybody's POS or does he just get suckered in a lot?
I'm not sure if you have the same engine/efi as my 95 Ford, but the acting like it's gonna die when you hit the gas problem has happened to me and some others. The problem ended up being a bad TPS each time. Mine would work fine for a while then all of a sudden would have no power. It would idle fine, but giving it throttle would make it want to die. Maybe you have a combination of this and a faulty regulator. I know it's new, but that doesn't mean it can't be defective.Quote:
Yaahhhhhh, about those TPS reports...
So it's pretty much down to Ed, Creighton, and myself. Hmm.....Ed, you just want to come to Dallas and drink? :)
I gotta get some wheelin in sometime soon. Maybe headed back overseas in a month or so.... BMRA maybe?
Or what about the new park north of Ft. Worth???
whiskey tango foxtrot?
I thought I told you this???
My unit was called up.
Not really. I will give you a call and fill ya in later.
theres fall quarterly or whatever at bmra in oct. scott knows when it is and plans to go. i will probably show up with ranger two in tow.
I showed up for some tiger woods golf, then some how ended up in the drivewayQuote:
thinking of that you need to work on your guy
yes, I know. I really need that 8.5 degree driver.
Flem, let us not forget what happened the last time you went to college and spent all your time on Dexter! Remember? Hmmmmm? :flipoff2:
try running the codes on it again. you can also need to test things like the tps and **** like that. didn't it rain on your motor a few times when the hood was off?Quote:
I think that is the same weekend as the work weekend and I think that makes it Oct. 26-28?Quote:
we checked tps, its a smooth transition all the way up
I still think its ICM, but those are kind of pricey
can't some parts stores test the icm?Quote:
not really, its usually a heat thing. probably works great in a 70 degree store.
junkyard+pocket=replacement icm ;)
sounds like a job for the magic bagQuote:
Originally Posted by Fredo
but it actually isnt that expensive. at least compared to that new fuel pump
http://www.partsamerica.com/productd...pe=194&PTSet=A
if thats not the right one...
http://www.partsamerica.com/ProductL...pe=194&PTSet=A
Looks like it is just Creighton and myself right now. Ryan is a maybe for a ride along. I updated the list here.
if you can find a 94 or 95 it'll have a remote mounted ICM with a big ass heat sink, same ICM, slightly different distributor but you can just extend the wiring and make it work.Quote:
Originally Posted by RCook527
ok, well I am down, yall can puss out all you want but Ed and I are going to have a great time
A bunch of us will be in Gilmer if you guys want to drive a little farther.
Andy, I appreciate the offer but I think Creighton and I decided we wanted to get some good redneck veiwing in this weekend. He is just waiting on his new choos for the jeep to show up and I am finishin up loading up right now.
Last call for a ride out there.
howdy yall, im out here in Nacogdoches at SFA with my two friends. We are coming out there. We are all members of the off road club, im a newb. Can you just let us know what channel you will be on? We'll be on channel 12 if we cant get ahold of you guys.
TAMOR is usually on 12 as well. They will have a BIG purple chevy, red chevy dually w/ gooseneck and a yellow TJ.
just look for the drunk rednecks, you can't miss them! :gigem:
