Think about that. Do you really trust a transfercase that was rebuilt by a canadian?Quote:
are there any differences in the shift rails of the early vs. later chevy 205's?
Yes one of the pair are different lengths IIRC.
I'll trade you rails as long as they are useable... I have the old one'sQuote:
Cool I'll try to drop the tcase before the OSU game and throw it in the truck.
If you're going to be replacing those wheels, I could use them.
I told jerry you'd have wood over them.Quote:
Originally Posted by eight
it will be quite a while. File me away with the guy with the k20 that you keep in your inventory.Quote:
Forked around with it today and yesterday. Cleaned most of the dust out of the engine compartment, and some of the crap out of the cab. Hooked up the starter tonight and turned it over some till the starter began making awesome sounds. :rolleyes:
Cool rig Jerry. :gigem:
Oh yeah the guy down the street from me came over while i was putting the starter on. He has an EB he made into a 4 door that's been in his garage for a while.
The dude rode up on a razor and his first words were "OK when did you get the beast" :D He also confirmed that the previous owner was canadian, and that the interior did indeed have some animal droppings hiding somewhere. :gigem:
I think the general consensus at hooters last night was we could have the truck up and running in a weekend with this:
http://cgi.ebay.com/ebaymotors/Edelb...spagenameZWDVW
and krebs shift rails.
May be put the tpi in the attic for a later date.
I have a 600cfm carter in my attic......Quote:
is it happy?Quote:
I think so. I started the truck up with that carb on it and it ran decent.Quote:
I can not remember if its electric choke or not? I will look at it tonight.
cool, let me know. $40 for a rebuild kit beats $250 for a new carb.
There was a cat living in my storage shed in lufkin. So it might have some cat pee on it.Quote:
A few things to think about before going to a carb.
Fuel pump? A FI pump will be way to much for a carb
Tranny kick down
throttle linkages
distrubutor? FI distrubutor will probably not work
Coil?
Etc
It might be easier to fix the FI......
****ing rednecks. Just do it right once and be done. :pQuote:
I have a distributor and 2 coils that came with the motor, i'll do some google research, me and karl already talked about a few of those things.Quote:
I might have a line on a intake for yeah. I am guessing you need one of those too huh.Quote:
sho nuff!Quote:
if your going to ditch the tpi and put a carb on there, you might as well pull the 350 out and put a 345 in there. fred, you know where he can get a cheap one?
maybe I missed something...what's it lack to get the FI working?
Originally Posted by mudtoy67
motivation
its temporary to get it running/inspected .Quote:
Originally Posted by agjohn02
The guy never got the TPI to "work" it fired once and never worked again, I have no idea what the guy did, what any of the wires are, and since i dont even know what im looking at that makes it even more fun. I could throw alot of money at it and still not have it work, or spend $200 on a carb and have it run in a weekend.
I was actually searching the other day cause i thought flem recommended a book on it, when i found ididoth's shat.
My theory is this, when I get out of school, i plan to drop some coin and set it up exactly like i want, i will most likely ditch the motor that's in it now for a 5.3 or something of that sort. I just want to get it running now and be able to comprehend wtf is going on when it takes a shat. Not constantly jiggling wires and checking voltages on the way to work.
i dont know, exactly the problem.Quote:
if you get it running on a carb, its gonna be hard to pull that apart and do the fuel injection in the future. i volunteer flem to come help you with it and get it going cheaper than you can do the carb swap.
just tell him you have tiger woods golf or guiter hero
Fred/Flem...
will the xxxx7747 TBI computer I have work for the TPI since they are both batch fire? If so I could bring it over and we could do some tinkering sat. night. Maybe an un-****edwith computer would help.
ive never cared to learn the intricacies of tbi but i am under the impression that its not batch fire, more of a metered constant flow. am i right?
Yes TBI is just a steady flow of fuel. You can watch it if you take the air cleaner off.
Yes, you can watch it, and it looks steady. But if you listen, you can hear it's just fast pulses...it's not a smooth flow. This is why I thought it could be related to batch fire. :confused2
yeah i plan on getting really hammered on sat. night, working on turd probably is not on the agenda. I just went out and ****ed with it some more, the starter is a piece and will need to be replaced.
I had a long reply written, but my apartment internet sucks ass and it dropped right as I hit reply and lost it
going to tailgate tonight? If so, we'll talk
i've got some of those tpi ecm's floating around if you suspect its the problem
747 uses peak and hold driver, it might not be able to supply enough current to keep 4 injectors open
I think that kit eric was looking at from edelbrock uses the later tbi computer to drive 4 injectors per driver, but there could be some fancy electronics between the computer and injector that they supply.
don't carburete it, you have access to the Flem, use his power for good. ******!
If ya do decide to sell the TPI, ill make ya a deal.
EL BORRACHO...Spanish for "THE BORRACHO"
Looks good.
Are you alive?Quote:
Originally Posted by AgDieseler
He was as of Friday, I seen him. He was wearing a WRX racing jumpsuit, and one of those shiny rainbow baseball hats that had a Subaru emblem on it. He was the hit of the country club. :rainbow: :flipoff2:Quote:
My carb is in pretty rough shape....The butterfly plates are frozen. I think the cat pee froze it up. It needs a good cleaning..
Its a manuel choke...
I think its a 625cfm carb
I will try and get the part number off it to see how much a rebuild kit is.
Also I am not sure if the linkages are set up for chevy or ford....The eb linkage was not the standard ford stuff I have seen before.
I think my sister's bf has a stock 4 barrel intake for a SBC...
sweet let me know how much he wants for the manifold and what you want for the carb.
Went out and ****ed with it some more today. Cleaned all the crap out of the back, found more rust, and located and eradicated the offending animal droppings.
Jerry, I will so kick you in the nuts if you put a carb on this thing.
Seriously. Right in the fruit stand. Repeatedly.
Get the engine running with the FI.
