The reason you lost 2ft is because of your winch/toolbox configuration. cant bring anything all the way up to the front. Or at least i don't because the winch always doubles as a tie down. a 20ft set up like you have would be perfect.
mine is 18, the tool box is on the tongue so it doesn't take any deck space and the winch is removeable and any truck can pull up over it if it has to, still wish i would have gotten a 20 or 22
Mine's 12', you have 15" more wheelbase, so the next size up is 14'.
Mine is 16'. Of course my tool box is on the tongue. I can fit regulat cab long beds or extended cab shot beds. Anything else is too long. It is perfect for jeeps, reg. cab short beds, and any car.
see above for thoughts. (JB, I don't want this to seem like I am calling you out, but you just had a lot of what I wanted to comment on.) :beer:
Weight breakdown of Wood vs. Metal on a 84" x 20' trailer (140 square foot).
2"x12" pressure treated= 924 lbs.
1/8" plate = 714 lbs. (-210 lbs)
3/16" plate = 1078 lbs. (+154 lbs.)
1/4" plate = 1428 lbs. (+504 lbs.)
Information gathered from these two sources.
http://brownlumberservice.com/PDF/lumberweight.pdf
http://www.chapelsteel.com/weight-steel-plate.html
that weight for wood sounds like wet pressure treated i bet it gets alot lighter as it dries out. also steel plate is slick as hell when it gets wet and things like to slide around alot on the metal decks
once the deck is dry it will be closer to 600 lbs
and if you have to work on something and it is sunny out steel sucks, that and the coeficient of friction is higher on wood is why i got wood
I would rather have a steel deck any day off the week for any job. treated southern yellow pine(what most smaller trailer shops use) is not what real trailer decks are made of it crackes and splinters with any real concentrated weight. with a steel deck d rings can be put down almost anywhere so the load can be properly secured using straps no way i am relying on the decks friction.
who said anything about not using straps. thats just plain stupid
I think what he is trying to say is that if you are having to factor in the 'friction coefficient' of the deck then you are not strapping the load correctly to begin with.
it was also refering to when you are working on something when it is on the trailor and not totally strapped down
So you work on your trailer when it's sitting at a 45% angle??? :flipoff2:
Someone also mentioned using a winch as a tie-down earlier in this thread as well...
