Don't worry about it, but if you want try bake one of the ceramic spray paints on. On the last couple dirtbikes I've had I've used that VHT stuff and its surprised me how well it's held up.
http://waco.craigslist.org/pts/3934121469.html
Guy says they are 3 years old but I thought they went to KM2s a long time ago
Has anyone replaced a key cylinder in a 91 ford without having the key? If so how ?
Big hammer....
Flat head screwdriver and a hammer
Mexican in the parking lot of pick a part... Seriously, there is a Mexican lock smith in the parking lot. Additionally for tools he has a file and a set of channel locks.
i know in the gm columns you need to remove the steering wheel to get to the cylinder retaining mechanism not sure on the fords
I'm trying to mount a center console in my truck but I need some sort of nut that I can stick in the hole in the floor and have it expand as I tighten it. I can't get to the other side as it is inside a body cross member. I've already tried well nuts and they pull out before expanding and I don't want to spend $50 trying to make nutserts work. Any other ideas? From the factory it had riveted studs in the floor but whoever put my console in made them loose and they don't stay in anymore so i can't reuse those.
why would nutserts be $50. Pick up a few blind nuts from the hardware store and make yourself a crude tool too tighten them and hold them in place.
I don't have the tool and the cheapest package at grainger is $25. Lowes didn't have any. All they had was well nuts.
use a bigger rivet
Bigass self tapping screws.
We use self tapping screws for everything. If they made one big enough I would replace my head bolts with them. I agree.
Anybody ever put new clutches in a Ford limited slip? Did it work or did it still slip? I'm going to try new fluid with no friction modifier first but I'm thinking it needs new clutches.
