the blancer is from a 350... at least that is what i asked for and told them like 5 times its a 350 not a 305 and thats what it said on the box... so it should be fine.Quote:
yes the distributor is from you, it is a in cap coil, i changed the vacuum advance on it cause it wansnt working, and the cap and rotor on it cause they were rusted like a mother ( actually dist. only thing i didnt buy new for the truck )
the engine is rebuilt... i bought the short block from the man above and i put the oil pump, lifters, new heads, intake, carb, water pump, blancer, etc etc etc all togetherQuote:
the distributor was the only thing used and questionable.
the motor was rebuilt and still in the plastic covering
scoggins dickey kit
4 bolt main
bored .30 over
aluminum flat top pistons
300 horse cam
steel crank -- i think
and its new lifter and new heads
so.....
