i second the 3 link with a panhard/trackbar
super simple to build and seems to work very well
Appears you are recreating my suspension.
What you are creating is basically a swingarm. As you know, swingarms don't flex. You must use some soft bushings to allow for it. I would stay away from poly for these.
On mine I had to go with the top link roughly half way down the lower for clearance with the frame.
Good idea on the bend in them, I think you will need it since your frame is wider than mine. Mine rub just a bit, but it's at about the same point the u-joints would start to bind.
Leaf springs are for suckers.
With the bind that setup will see and the weight it's going to have to hold up, the bushings are going to catch pure D Hell like kolpecker said. I think the 3link will serve you better.
Klogger replacement!!
http://houston.craigslist.org/cto/1738773285.html
im wet
You piss your pants again???
Thats a pretty good deal, fuel injected 460, Dana 60 w/ locker all for 3k. Of course you have to wonder why the tranny and t-case are not in it....
It's time to have the WTF am I doing conversation, so let's have it. Please read below and comment. I am not looking to get into a Ford vs Chevy drivetrain debate, just trying to figure out my next steps and think some stuff through. When I built the Klogger I made a booze cruising, very low budget, people transportation device. I would not call it an off road rig. For the past 5 years I have wheeled it with only about $1000 in it (truck was free, cab wad free, lift was $150, FI engine was $300, Tires $400, I have put some other stuff in it, but pretty low budget, recently I have put a manual in and a doubler, but for a good 4 years I only had about $1000 in it). I think it has served it's purpose, We all had fun, it transported people and I learned a lot about off roading, etc... Now I have quite a few higher dollar parts that I have not installed and am debating weather to polish the tird further. Here is what the Klogger currently has:
* Good running 351 V8 with Ford Fuel injection (new timing chain, water pump, 140 amp alternator upgrade, upgraded saginaw power steering pump)
* NP 435 with new clutch, hydraulic clutch setup
* Offroad Design 203/205 Doubler (4:1)
* Twin Traction Beam Front Axle - Best axle ever
* Sterling 10.25 rear, good brakes, 3.55 gears
* Roll Cage, not the world's best, but better than nothing
I have the following parts I was going to put in it:
* Dana 60 - have 35 spline outers, wheel flanges, drop in locker, 5.13 gears, hydro assist steering, essentially when built an axle worth close to $2000
* 5.13 gears for the Sterling
* New rear leaf springs
* Chevy 52" leaf springs for the front
* 42" TSL's on Trail Ready bead locks
My plans were to put all this together and have a locked front and rear full size on 42" tires. This would be the easiest route, but I am debating weather to move forward on this plan for the following reasons:
* A stock F-150 reg cab weighs 3900 lbs, a crew cab tips in at about 6000 lbs, say the difference in a 150 and 250 frame is 1000 lbs and the other 1000 lbs is the body. I essentially would have a locked full size tipping in at 5000 lbs, or a ton more than a jeep. This makes hill climbs suck, breaks more axles, etc...
* It's a f'in full size crew cab, even with great axles, gears, tires, etc.... I would be pumping a bunch of good parts and money into a vehicle that will never be the most capable off road rig.
So my options:
Option 1 - Remove the crew cab body, scrap the cage and build a new one:
ADVANTAGES
*About 1000 lbs less weight
*Easy to do, most everything would just bolt up since the truck was originally a reg cab
*Not as large as the crew cab
DISADVANTAGES
*Still on the heavy side compared to Jeeps
*Still wheeling Full width
Option 1.5 - Full size Bronco Body, not really an option to me because it would still be full size/huge and weigh 5000 lbs.
Option 2 - Ford Explorer with V8
*V8 already installed, so no bastardization there, it bolts up to my existing NP435 and doubler
*Narrower than a full size
DISADVANTAGES
*The things weight 4000 lbs, Holy crap an explorer weighs more than an F-150
*Would have to cut the ass end of the explorer off and still wheeling a pretty big vehicle
*Running Explorer buy in price is $1000
Option 3 - Ford Bronco II
ADVANTAGES
* Weighs only 3300 lbs, just a little more than a CJ, about equal to a cherokee
*Narrow body, yet a 32" wide frame. A F-150 has a 33" wide frame, somehow a small bronco ii has only an inch narrower frame, this way things like a NP205 will fit, this is not the case for early Bronco's
*If you outboard the spring hangers, it fits current F-150 axle width's for purches
*Cheap, there is one with no motor or trans on the list for $200
DISADVANTAGE
*Fitting a 302 in one of these is hard, Fitting a 351 sucks and requires 3" of body lift or a lot of work
*Owning a Bronco II
Option 4 - Jeep-dom - Lets just say other narrow rigs, Jeeps, Scouts, etc...
ADVANTAGE
*Narrow
*Light Weight
*I hate Jeeps, so when I ram something I will not be sad
DISADVANTAGE
*Motor mounts, wiring, etc... a lot of work
*Owning a jeep
*High entry price, somehow people still want $2000 for a rusted pile of dog crap
Option 5 - The Unicorn - Find someone who has a buggy set up for a Ford engine and axles, but with no engine, trans or axles, and rape them on the price
ADVANTAGE
*Light weight
*Most capable
DISADVANTAGE
*Like finding a unicorn, and once you did, it would probablt be expensive.
Define "good running".:flipoff2:
You sure an extra two doors and some sheet metal adds 2100 lbs?
To use everyone else's example...JB's rig can't weigh much less and his does great.Quote:
Do you have an alternative rig in mind? Or are you just figuring whether to proceed with the Klogger or start looking for an alternative?
edit: guess I didn't read the next post.:laughing:
The primary reason I started taking apart the cruiser was I went back to school and didn't have any money. The reason I took it further and it is the way it is now is I got tired of all the janky stuff I had done before. If this is where you are starting over may be a good idea. You've got a lot of good parts laying around and would just need a good chassis.
Good running - it started every time this weekend, when I pushed the go pedal, it went. The idle was ridiculously high, but I am pretty sure I can fix that.
JB's rig is the exception to the rule, and even so he frequently breaks axle shafts, etc... Additionally it will always be wide and heavy, therefore at somewhat of a disadvantage.
I am not saying I will not stick with the Klogger, just thinking it is time to evaluate it before moving forward. Unfortunately (or fortunately, depending on how you look at it) I have a Ford doubler and a ford (driver's drop) Dana 60, this means I am pretty well locked into a blue oval for motor/drivetrain. If I had a SBC and chevy t-case I think my options would be a lot more, since chevy drivetrain swaps are more common.
I would search for that unicorn 4-seater chassis with room for a cooler in the back.
All of that glass and sheet metal just seems to get in the way! All of your passengers can take the rain and cold just fine, who needs a roof and doors.
Super light weight, great visability, will go anywhere - less chance of breaking, room for a future kiddo and safe for them too...
I believe Garrett is doing this same thing (also with Ford crap...). He got wise - even with a capabale narrow EB
