so basically a narrowed dodge 60(external hubs)?
basically a land rover front 60 ;)
Is it an actual 60 diff with all the limey sh!t stuck on the outside or the britt's interpretation of what a 60 should be (metric and gay)?
its cast over there in Salisbury, referred to as a Salisbury too
everything in the diff is the same except the outer pinion bearing. they have a wierd spline count, but I think some domestic stuff use the same count since there is a lockrite available for it and 4wheep parts doesn't know that it fits them.
Sunbeam Tigers also have an axle that is referred to as a Salisbury, its a dana 44
they make crappy steaks too
I'm going through a bunch of old computers that were at my parents house and copying important stuff before junking them.
I came across this gem from 9/30/01
ahhh... the first time i met RJ's dad...
i also remember hearing about the "TAMOR Jeep" that flipped when i turned my bus in after the game...:gigem:
RJ's Dad requested to go to the large animal clinic. The sad part was (IIRC) there wasn't a scratch on the side that got T-Boned. The little ricer hit the rear tire and over it went.
found this. . . http://www.roxtarfab.com/acc-reardoor.htm
The powdercoated one looks like a pretty sweet deal.
made one fo free
rover porn!
nice alternative to the toyota 3rds or gbr overprice junk.
thats a ford 9" gearset
http://i6.photobucket.com/albums/y204/ashtrans/D323.jpg
http://i6.photobucket.com/albums/y204/ashtrans/D320.jpg
http://i6.photobucket.com/albums/y204/ashtrans/D324.jpg
so did they shave the bearing caps to make it fit? where's the write up? what are those C's? look expensive. if it's cheap maybe I can make them for the pink panther. I can find rover axles all day for cheap.
ashcroft is manufacturing the 3rds
