I was thinking of questioning your putting of good drivetrain components in that thing. If you put them in a smaller rig, it would be more capable than mine is. You'll have 42s, you could run whatever Davido runs.
I think I'd like to see the explorer done. I would not swap the doubler in, you know what that thing weighs. Sell it to some stupid fullsize guy and find a used Atlas or Stak. I see them come up pretty often for things that aren't a jeep. This way you are not bastardizing anything to do with engine/transmission. You can also keep booze wheeling the klogger until you are almost done and need to steal the rear axle, as that's the only part you would need from it (or find another sterling). I bet the explorer will lighten up quite a bit when you chunk the doors, lift gate, and anything that sticks up above the dash (yes, chop the whole roof and windshield off)
Formula for Explorer build.
- Buy explorer
- Remove doors, hatch, windshield, roof. Gut AC (keep compressor for OBA), heater, all other junk that isn't needed. If it has weight and isn't needed, pull it.
- Build cage
- Swap transfer case
- Swap axles
- Add driveshafts
- Install 42s
- Add other stuff
- Kick Ass
Oh, leaf springs don't belong on serious trail vehicles, especially with the badassness of 42s.
