is binderplanet the old binder bulletin? i had a guy e-mail me asking me tech questions about my scout the other day saying he saw it on binderplanet. i've never heard of it...
Yeah John, something happened between a couple of the people running it I think and there was a split. Binderplanet got all the old binderbulletin board info.
where did the grand go?
$300 machining of heads, fixing bent valve
$100 head bolts
$200 gaskets
$50 oil change (twice)
$100 o2 sensors
$15 fuel filter
$60 coolant flush/fill (twice)
$40 block sealant (that didn't work)
$25 spark plugs
$10 plastic rivits
$10 thermostat/gasket
$10 non-hardening sealant
$10 gasket instant adhesive
$5 brake cleaner
Good place in town for powder coats?
I thought I remembered you from somewhere (and that is one ****ty wig you have now)! :gigem:
http://1.bp.blogspot.com/_9jQG1FJwo2...400/powder.jpg
well played sir!
eastwood? you watch too much tnn. harbor frieght has the shniz to do it now.
harborfreight doesn't send me an email everyother day, eastwood does :)
Texas Truck Riggins does powdercoating. Wtf would you powdercoat on a jetta?
Truck Riggins (small stuff only) did my Baja light mount and Texas Custom Coaters (any size) in Navasota did the Jeep frame and cage.
Texas Custom Coaters did my axles. Good work.
i think thats the one off hwy 6 up north past hwy 21. don't know for sure though.
Their.
And here I have your powder coat solution:
http://www.rustoleum.com/cbgimages/p...RHmsBlkSpL.jpg
blankenship, i think you are thinking of t3 or take 3 or whatever they call themselves
So apparently the wheels I picked up today were not 16x8's but 16x7's. Man the guys at Crosby farm and tire are gonna hate mr when they mount up robbies old tires...
Hopefully it is even possible to get them mounted. I know it was a a real pain for me to mount the 15x8's from the frickoneer on the 16 inch wide boogers. If they do fit I won't have to worry about getting beadlocks, and my tires will prolly measure 39.5" now.
I have mounted 38 x 15.5 x 16.5 tires on 16.5 x 5.5 wheels. That part is not hard at all. I may be a little badder dude than most, but me and 2 screwdrivers can make it done. Breaking them off is a little different, maybe Andy could do it.
brians tires were on stock 7 inch chevy steelies for a long time, house of tires had no problems mounting them
which is mo' better?
700R4 or TH350
im leaning towards the 700R4 for the lower 1st.
condition, price, adapters, etc the same.
a modern 700 is stronger but has a TV cable to worry about
at least it works in the rain
what is the threshold for a D44 ring and pinion. 5.13? 5.38?
I have 4.88s and they looked small. I can't imagine that 5.13s or higher would have anywhere close to enough contact surface.
I think 5.13 is the lowest you can go you get into a real small pinon even me d60 5.13s have a small pinion
What size are Jeep YJ body bolts? Are all 10 the same or are the four rear ones smaller? I don't have one here I can look at.
pretty sure the rears are smaller.
I know the mounts are smaller. I don't remember if the bolts are too though.
Call Brett. He's probably sitting around with his thumb up his ass.
800-699-5337 x231 I think it is 231. He's at my old desk, so I think that is his extension.
It is, I haven't had time to check on it though.
Do you know what size the bolts are? I need to know how big of a hole to drill in something to put them through, not necessarily the length.
FYI- The front 6 bolts are 1/2" and the rear 4 are 7/16" along with the grill mount bolt.
Sorry, I didn't see your last post before I left last night.
What year range np 203 do I need to do a doubler on my sm465/205. The trans is a ten spline model with the figure 8 adapter.
