from my research the LQ4 is actually a better starting point if you plan on adding boost because of the lower compression, not that I plan on adding any boost to it
http://i46.photobucket.com/albums/f1...p/IMG_2348.jpg
http://i46.photobucket.com/albums/f1...p/IMG_2352.jpg
http://i46.photobucket.com/albums/f1...p/IMG_2351.jpg
oh and Ryno you could use some new casters on your engine hoist :flipoff2:
hmm, looks like you are in the same situation as me!
yes but I bet yours will be done first.
hmm - that's what I need!
So it looks like I am going to go with a 5.3 and th350 now maybe even try to run the 231/300 doubler.
http://cgi.ebay.com/ebaymotors/Used-...Q5fAccessories
This is what the 5.3 really needs
Nawz!!!!
so it looks like you can put 700r4 planataries in a th350 for a 2.98:1 1st gear
http://i46.photobucket.com/albums/f1...d/IMAG0009.jpg
Amazingly this whole setup is about 2-3 inches shorter than the nv3550 231/300 combo. I may have to clock the 300 down to clear the trans though
http://i46.photobucket.com/albums/f1...d/IMAG0010.jpg
