bring part numbers for a few brands if you can, they don't seem to be able to look up auto applications. Yeah mention Jimmy and TAMOR, I've been trying to butter those guys up for a discount.
damn i just called randy's to get an idea on price. for just the Bearing kit it was $130 for the dana 60 and $177 for the 10.25. can Pulvis(sp?) beat that
bookmarked... thanks john
uno mas....
http://www.tsmmfg.com/2670.htm
Last month I was in town and had about an hour to work on the bronco. I pulled the pass side rear hub off and pressed out the studs. I am now going back on the thought that I would have to grind down the hubs a lot. If I do any it is gonna be very minimal. After looking at it more the disc swap has maby 3 hours worth of work to finish it up less running the lines. I still need to order some brackets cause I really dont have time to build any. I have been working on average 65hrs a week here in SA so I don't think much progress will be made soon. After the christmas holidays I need to hit it hard though. I am planning on using the bronco for the getaway car for my wedding June 2nd. so a LOT has to go down before then. I will make it aware when I come to town if any before then. I can use as much help as you guys are willing to give me. The main work will be after January 1 though. And I will need a lot of help if I am gonna get it done by the new deadline.
Thanks
Tate
well Austin and I came into town the other day and worked on it once again. I ground down the hub and put the rotor on the side i had off and took off the other side, the gears are 95% set in the 10.25, got the pattern right and all just have to pull it apart one last time and put the new crush sleve on the pinion and press in the pinion seal and then put it back together, by the way it took a lot of shims, but i could not be happier with how it feels, I need to borrow a set of setup bearings for the 60 so i can get that sucker set up
ive got a set you can borrow, including pinion nut.
thanks, i will call you sometime in january to come and get them
It makes me sad... I was in CS yesterday and I looked at my bronco... I need my house to be done so I can start working on it again
Let me know when you clean that shop out - should be interesting.
i have gotten rid of most crap... i took the doors, fenders and hood from the f350 to bryan iron... i still have transfercases and such left though... and some dana44 parts and brackets and whatnot
do you have any radius arms and spring perches for the 44??
no i traded burris a while back for leaf-sprung ones for Nix's ranger
