Same basic concept. They use a power steering pump to build pressure to release the brake. It's a drum setup that has 2 wheel cylinders, one for normal hydraulic braking and the other has springs in it that will lock up the brakes if there's no pressure to release them, so there's no leak down there. I just after something that'll hold the bronco on a hill and pass an inspection
