I found out the trained versions that get paid aren't much brighter than the minutemen... I can't work with people that stupid when my life is on the line.
no job that pays you to put your life on the line is gonna attract the brightest crayons in the box
Seriously, I've **** smarter things than some of those kids... And they all had to go through the same background check I did. Unbelieveable.
Grad school here I come. Full time job for now, then cut back in the fall to start at either UT-Arlington or Texas State.
well, I guess some rodents are considered to be fairly intelligent :flipoff2:
you would need a subcontract, a purchase order is for goods not services :flipoff2:Quote:
Originally Posted by BMFScout
good call, feel free to wite up a revision and I'll submit it directly to the higher-ups without taking anytime to look it over.
:D :flipoff2:Quote:
This thread is on it's way to being properly hijacked :laughing:
Wait, let me help...
[Jimmy] Coco Loco has the best mexican food in Bryan [/Jimmy]
hmm is that the same as this?
thats why your thread is now on it's way to syria. you just edited the post to make you look right instead of discussing the tech like you should.
anywho, you have zero caster im assuming and the pinion is still pointing down some. scouts came from the factory with zero caster till '80. it should drive better but not as good as it could. referr to my post a while back about making it too complicated or too easy...blah blah. you made it too easy and its still messed up.
take some pictures of the new anglesQuote:
why do i feel the need to post this...
Originally Posted by stinger7401
Originally Posted by RCook527
you're just mad because i called you dumb. thats not a personal attack, its scientific fact. the proof is in your post. :flipoff2:
My uncle has a pocketknife.
Originally Posted by agjohn02
when was i involved in this waaah-athon. if you called me dumb somewhere, i didn't even notice. i was referring to the rule offending posts on page before this
ah, the coop asterisk-fest... who called you dumb?
