I've got to pull the flanges to get them machined to rover driveshaft pattern so I ordered 2 of these. http://www.trail-gear.com/solid-pinion-spacer
Good idea. I went with the solid pinion spacer when I built the 9" third. I hate crush sleeves.
I'm thinking 4.56 instead of 4.10.
Is Precision the best you can get for Toyotas?
finished the rear axle today and got the tires bolted on instead of leaning in the wheel arches.
http://www.flemcodesign.com/pics/rearaxle.jpg
http://www.flemcodesign.com/pics/rearaxle2.jpg
http://www.flemcodesign.com/pics/3qtrshot.jpg
flange mods that I'll either have the same shop that did the spindles do, or I'll try to convince someone that these are dreamliner parts.
http://www.flemcodesign.com/pics/flange.jpg
I started on the front axle today, but the sleeves in the polyurethane bushings had rusted to the radius arm bolts so the axle had to be removed with those still bolted on. A trip to lowes for some saw blades took care of that
http://www.flemcodesign.com/pics/radiusarms1.jpg
drilled the new diff pattern and welded another pass around the front diff cover that had been leaking.
http://www.flemcodesign.com/pics/axlefixture.jpg
http://www.flemcodesign.com/pics/frontaxle1.jpg
Waiting on replacement bolts before I can put anymore back together.
[img]http://www.flemcodesign.com/pics/radiusarms2.jpg
look good flem
Hell Yeah! The slow boat finally showed up I guess. Those look good.
thanks. Fronts went on easy. Don't have any instructions for the rears.
http://www.flemcodesign.com/pics/seats1.jpg
http://www.flemcodesign.com/pics/seats2.jpg
nice
