i need 8 lug. thanks though.
in a couple weeks spend some time walking around the parking lot... im sure you could find some somewhere
John. I got these on ebay. Stroke of luck I guess. I have an extra one that I made as a pattern if you'd like to borrow it whenever you find a set. Basically, cut 3/8" depth off the bottom, and cut the feet even with the surrounding bracing. I cut out a 4.5"ish hole for the hub. It's all 'bout the Dremel.
I have two Gorilla lugs on each wheel, so the appropriate black covers are PVC glued in place on the center cap.
Gorilla lugs? I was gonna ask what you did lug-nut wise, since the later models with the screw on plastic lugnut covers were metric, but your earlier junk is standard.
You can buy the fancy external thread lugs with in 9/16 - 18 thread on ebay. Gorilla lugs are lockuts that keep honest people from stealing by wheels 'n tars.
some vice grips is all you need to get past them
Originally Posted by Shaggy
Originally Posted by AgDieseler
how much did you end up paying for the center caps, david?
I paid $45 shipped. I also picked up an extra pair for an experimental/prototyping set for $20 shipped (I didn't want to screw up the nice four).
I think the factory wants $50 per cover!
Corbeau sport seats received, upholstered, and installed - muy comfortable. Pictures are pending.
