I've got all this left. . .
-(1) stock cj roll bar, garnet colored.-$30
-(1) dana 44 passanger side knuckle that is f'ed-free
-(1) passanger side ford vent window frame and glass-$5
-(1) stock 2 piece axle shaft AMC 20-$20
-(1) cj slave cylinder and braided line-$15
-(6) 2" 2 degree shims-$10
-(4) 2.5" 2 degree shims-$10
-(2) tow hooks-$5
-(2) M.O.R.E. cage to frame tie in brackets, (look like body mounts)-$15
-(2) cj7 4" lift rear springs-$50
-(2) cj7 4" lift front springs-$50
-(2) dana 30 hubs with wheel bearings, spindle nuts and washers-$40
-(2) dana 30 rotors-$20
-(2) dana 30 lockouts AVM-$30
-(2) dana 30 knuckles with tie rod flip already installed-$40
-(2) b2 front sping plates 2" wide springs-$20
-(2) dana 30 spindles-$20
-(2) front braided stainless brake line 4" lift-$25
-(1) rear braided stainless brake line 4" lift-$25
-(4) dana 30 brake pads-$5
-(2) dana 30 calipers-$20
-(1) cj7 rear driveshaft, 1310s non cv-$30
-(1) cj7 front driveshaft, 1310s non cv-$30
-(4) rear shackles 2.5" wide springs, 4" long-$10
-(2) front shackles 2" wide springs, 4" long-$10
-(1) dana 30 short side inner shaft-$10
-(1) skyjacker nitro shock-$20
