brett are you going to flip the leaf spring around to move the center pin back?
I had glasses AND a full face mask on, so I figured I'd be ok. I wasn't. Luckily the doctor used about a bottle of those eye deadening drops so I didn't feel anything while he was drilling. Then I started realizing just how deep he went about 20 mins later while my mom and I (completely blind at this point) were eating lunch. I thought french fries and fried shrimp would be safe until I mistook three shrimp tails for a handful of fries...Quote:
Originally posted by BMFScout
I have found out the hard way twice to wear GOGGLES not glasses when grinding underneath a vehicle. The optometrist dremel tool thing with the rotary eye drill attachment sucks...
I'll do that eventually. I wanted near-stock wheelbase for now because to flip them would mean I would have to cut the rear fenders, which would result in the 33s looking even smaller than they do now... Damn I need some new tires.Quote:
Here's how the rear suspension looks. We ended up using a stock YJ shackle to get the angle right.
http://www.texasoffroad.net/albums/l...768s.sized.jpg
Here's the front with a 38.5" Gumbo Mudder next to it. The tire only measures out to about 35-36" tall, but this was for reference. The Jeep still has about 7-8" to go up since the front axle is at full coil droop.
http://www.texasoffroad.net/albums/l...770s.sized.jpg
Yeah, my friends 38.5x15 ground hawg is almost identical to my buddies 36x14.50 tsl rad.
What're your plans to level out the front? Coil Spacers? You should go 3/4 eliptical in the rear :eek:
those coils will make it sit level with the rear after the rear gets an add-a-leaf
amazing how fast you can do this, took Nutz how long to do his front???
I'm not working on school days and I don't have enough money to get it on the trail until Christmas break anyway so why rush?
I have the most demanding semester so far right now. I spend at least 3 nights per week in open access labs. I have a boss that doesn't think twice about working me until 4am on a school night and I am busy from 6am-9pm almost M-Th.
Why do you even care?
I think everyone just likes to give you **** for entertainment.
Yeah, we really don't care but it's too easy to pick on you:DQuote:
we'll still buy you a beer for the effort:cheers:
I'm pretty sure of that. :flipoff2:
Here's how the t-case came out. The 1350 flange looks really good up there. :D
http://www.texasoffroad.net/albums/l...3584.sized.jpg
I got my package from High Angle a couple of days ago. :cheers:
http://www.texasoffroad.net/albums/l...3588.sized.jpg
Here's a comparison of the stock shaft to Jess' 1350 CV shaft.
http://www.texasoffroad.net/albums/l...3589.sized.jpg
Here's the shaft. I'm honestly not all that impressed by it. It's heavy, the packaging was OUTSTANDING, but it's just not all that impressive. It's just a driveshaft, and I honestly think most any local, reputable shop could build almost the same damned thing.
http://www.texasoffroad.net/albums/l...3587.sized.jpg
Here's the beast bolted up and ready to propel my junk.
http://www.texasoffroad.net/albums/l...3600.sized.jpg
Here's the axle, ready to roll under the Jeep for it's final test fitting.
http://www.texasoffroad.net/albums/l...3591.sized.jpg
axle going in
http://www.texasoffroad.net/albums/l...3594.sized.jpg
Here's the pinion angle...
http://www.texasoffroad.net/albums/l...3595.sized.jpg
and here's the current ride height...little taller than we expected/wanted...
http://www.texasoffroad.net/albums/l...3603.sized.jpg
and this is my reaction to the fact that it sits around 11" taller than a stock TJ... FAWK!
http://www.texasoffroad.net/albums/l...3602.sized.jpg
(chop fodder)
After thinking about things, I decided that the DOM I got was better suited for some homemade links, and I'll go ahead and use normal TREs for my steering.
Here's what we accomplished tonight before I got ****ty drunk...
http://www.texasoffroad.net/albums/l...LCA1.sized.jpg
http://www.texasoffroad.net/albums/l...LCA2.sized.jpg
http://www.texasoffroad.net/albums/l...LCA4.sized.jpg
http://www.texasoffroad.net/albums/l...LCA5.sized.jpg
These are the lower link frame brackets. They're mostly 1/4" strap stock.
http://www.texasoffroad.net/albums/l...044S.sized.jpg
http://www.texasoffroad.net/albums/l...063S.sized.jpg
http://www.texasoffroad.net/albums/l...089S.sized.jpg
http://www.texasoffroad.net/albums/l...092S.sized.jpg
