285/75/16 = 285mm wide/ sidewall is 75% as tall as tread is wide/ 16" wheel. So 285mm * 1 in / 25.4mm * .75 * 2 + 16 in
By conversion, 285/75/16 tire is 32.7". 245/75/16 tire is 30.3", I think that's what your truck would come with. 265/75/16 tire is 31.5". You have to go by both converted numbers or both actual numbers by measurement. The tires will not measure what they say on the sidewall. The best way is to meaure from the ground to the center of your hub with both sizes of tire and multiply by 2.
